Difficulty To Swap Tops?
Old Jul 5, 2008 | 10:58 AM
joemauma's Avatar
Default Difficulty To Swap Tops?
Going camping tomorrow, considering taking off the hard top and putting on the soft top.
How long does this usually take you guys to do?
Old Jul 5, 2008 | 11:09 AM
saltman's Avatar
15 minutes.
Old Jul 5, 2008 | 11:10 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Hey Joe get that soft top on and down, it should take you much less than an hour
here are some useful links
see top instructions under operation and maintenance
http://www.project-jk.com/?cat=12
here is jeeps instruction for the soft top with a video
http://www.jeep.com/en/owners/soft_t...T8softtopguide
and one more
http://my.project-jk.com/showgallery...689&ppuser=480
Old Jul 5, 2008 | 10:09 PM
TINMAN080's Avatar
Remove hard top, unpack and install convertible top 1st time- 2 hours.
Old Jul 6, 2008 | 05:02 AM
BelgianJK's Avatar
Indeed. I did it yesterday evening... my first time: 2 hours.
I hope that with a bit of practice putting the softtop up will go faster ;-)
otherwise I do not dear to put it down here in Belgium were it rains on avarage 2 out of 3 days.
Old Jul 6, 2008 | 08:38 AM
yetibear's Avatar
If this is the first time you are using the soft top, expect it to take a few hours. Your are going to go slow making sure everything is attached properly, and then the top is going to seem like it is one size to small, and some of the windows can make you question your sanity. Park in the sun, the top will expand to a usable size, take your time, be sure everything is in it's proper position, and it will go on with surprising ease. It will just take a little time the first try.
Old Jul 7, 2008 | 06:21 AM
Spetz's Avatar
And make sure you take off the little rubber caps that are on the ends of the middle cross bar. I didn't and the soft top wouldn't properly attach at the front door..After it came off by accident, it worked fine..
Old Jul 13, 2008 | 01:41 PM
BelgianJK's Avatar
Hi thanks for this tip ;-)
I must admit that I found the plastic caps a bit awkward ... now that I removed them it is much easier LOL
Old Jul 13, 2008 | 03:07 PM
Gypsy's Avatar
Little rubber caps? Huh? I need pictures please.
First time, an afternoon, and a lot of swearing. Yetibear is right. Parking in the sun will save you a lot of headaches.
Second and subsequent times - about forty-five minutes - start to finish and clean up. I like to pack my hard top though. And I'm not the biggest person so some stuff takes me longer.
