Doing brakes, Brake pad grease packets..what do I do with that stuff???
So when you buy a new set of brake pads you get those little grease packets...exactly where do you use that stuff??? Does it cut down of squealing?
On the back of the pads where it will help prevent squealing. What it does is lubricate where the pads touch the calipers. The other option is to put it on the face of the rotors and they will never wear out. Of course you won't be able to stop either. I do put some never-seize on the part of the rotor that touches the hub. If you ever had a rotor get rusted to a hub you know why I do that.
he had just upgraded to brembo brakes and rotors... painful to stop in his car now... wish my brakes worked like that..
Thanks for the replies, in the past I have put a lil bit on the caliper slides but I never put anything on the back of the pad. (no wonder they squeak so much!)
I always put just enough on the back of the pads to make them wet looking. You don't really want much more than that. It's also a good idea to coat the rim of the caliper piston before reinstalling the caliper.
