Dome light won't turn off
I've had this happen before. I didn't realize that the dash light dimmer, if turned too far, will activate the dome light and it won't shut off until you turn the dash light down.
I hope this works for you.
The dome light is on a timer when you open the doors, so when you take off the doors, it should turn off by itself and that should be the last time you had to deal with it. I forget if my kight turned on after I shut down the Jeep, but if it did I turned it off. In either case, the light is on a timer and should evebually shut down. I'd take it to a dealer and have them check the programing.
