Door sensor
Old Nov 2, 2016 | 09:42 PM
jray02r1's Avatar
Default Door sensor
I just purchased a 2007 jkur and discovered that the door sensor in the front drivers door seems to not shut off the accessories when i shut off the vehicle and get out. All the other doors work. Is there something i should look at first?
Old Nov 3, 2016 | 06:43 AM
resharp001's Avatar
Loved
Community Favorite
I'd start by checking the wiring harness on the driver's door. It seems like the jeep is just not recognizing when that door is opened if i understand properly. Unclip the harness and verify all the pins are making a good connection.
I had to resolve an issue with a wiring harness earlier this week. Not sure if you're harness is similar on an '07, but the idea should be the same in regards to a wire working loose -
https://www.jk-forum.com/forums/jk-e...solved-337996/
Old Nov 5, 2016 | 12:13 PM
jray02r1's Avatar
Contacts are clean. I just was playing with it a bit and noticed something. When the door is open (radio and accessories are still going) if i push up on the door latching mecanism the it will kill all the power as intended. I am not at home, so i cannot loosen the torx bolts and see if i can adjust it any. Doesnt reall look like its adjustable tho.
Old Nov 5, 2016 | 01:05 PM
14Sport's Avatar
Looks like it can be adjusted on my '14. There's tape over the adjustment screw access hole. Maybe it's the same for you.
Name:	2014 Door Latch Adjustment.png
Old Nov 6, 2016 | 12:58 PM
14Sport's Avatar
I just checked mine and there is no tape over the adjustment access hole.
Name:	Door Latch Adjustment (Large).JPG
Old Nov 7, 2016 | 09:46 AM
jray02r1's Avatar
Thats how mine is as well. I tried turning it clockwose, but it wouldnt go at all, when i tried counter clockwise it would act like the bolt was almost out and would not change anything.
Old Nov 7, 2016 | 11:18 AM
14Sport's Avatar
The instructions say to loosen that screw 1/2 to 1 full turn. Then operate the handle several times. Then retighten. That leads me to believe it's self-aligning and the screw just holds it in place.
