Door Surrounds
Door Surrounds
Have the typical soft top leak. On passenger side got so bad that the seat belt got frozen in place. Just checked today and my surrounds are really loose. Tightened the bolts and now they are snug as hell. What are the chances that may alleviate the leak or at least make it taper off some?? Thanks
Make sure your door surrounds are sitting properly and the header seals A Pillar and seal B pillar are not rolled in or distorted:
From Chrysler TSB:
“Rolled” or distorted
windshield header
end seals can cause
leaks by making a
poor transition for
the primary seal to
seal against.
“Rolled” or distorted B pillar
mucket seals can
cause leaks by making
a poor transition for
the front or rear door
primary seal to seal
against.
I had a similar issue when I removed the hard top to install the soft. I had not realized that the mucket and seal had rolled under the surround and that caused the leak. Once I fixed it the leak went away.
Using a pdf suggestion someone posted I ordered some camper tape to try to replace the mucket seal and see if that will alleviate the issue. Looks pretty simple so it could be a $6.00 fix.
