Door will not open - Passenger side rear
Well, my daughter got out of the jeep very quickly and shut the door on the seat belt. Kind of a weird click sound as she did... Shut it on the seat belt... Was able to get the seat belt out easily with door closed (top is off), but now I cannot open the door.
Any ideas? Seems to lock and unlock correctly, but it just won't open. Please help! |
any chance she turned the little white screw like locking mechanism (child lock) that's on the corner of the door? its a poor design but who knows...:thinking::thinking::thinking:
Should still open from outside if child lock is on? This has me stumped for sure
Argh! Still can not get this door open. Any ideas?
Maybe try taking the hinge off and see if that helps
Originally Posted by Covert_Ops
(Post 3602706)
Does the button push in but won't open the door? I had this happen on my front door..fixed under warranty. Apparently the retaining clip that holds the cable inside the door wasn't set properly at the factory. When I pushed the button on the outside to open I could hear something moving but no open...hope this helps.
Thank you. Yes button pushes and handle works on the inside.
Same thing mine was doing...handle would work on the inside but not outside.
