double click from left rear
Old Jan 8, 2012 | 05:58 AM
klutchdust's Avatar
Default double click from left rear
08 JK stock suspension 73000 miles. From a dead stop I get a double click from left rear tire area. I use two different sets of wheels, always torqued and rechecked, all undercarriage mounts checked for tightness. Sounds like a loose wheel click. It happens occassionally . If it does it and i stop and try to duplicate it ,it won't do it. recently changed shocks, it did it with original shocks and replacement shocks. IDK.
Old Jan 8, 2012 | 11:48 AM
JKlad's Avatar
Axle bearing on the way out? They often start off with just a click when coming to a stop & then progress to a rythmic ticking when underway.
Old Jan 8, 2012 | 12:43 PM
klutchdust's Avatar
Could be, odd thing it does it when it feels like it and not when Im standing next to it with little woman in driver's seat. I plan on pulling the wheels off and checking everything again.
Old Jan 8, 2012 | 01:32 PM
mjones's Avatar
Check your emergency brake cables and emergency brake system in rotor. sounds like the same i had. adjuster and springs were shot on my drivers side.. i fixed both brakes and silenced now.. if you are breaking it down, i would go all the way down.
https://www.jk-forum.com/forums/show...mergency+brake
Old Jan 8, 2012 | 03:05 PM
klutchdust's Avatar
Thanks for the thread referral, it was an interesting read. I wasn't able to replace the brakes when they failed due to illness, good time to see whats going on back there.
Old Jan 13, 2012 | 07:49 PM
Coley's Avatar
Put it up on 4x axle stands, start it an put in in 4hi drive. Check for rear wheel wobble. Sounds like the bent rear shafts I had.
