Sponsored by:
Sponsored by: DashLynx
Drag link servicable?
Old 11-06-2012, 05:24 AM
latief's Avatar
Default Drag link servicable?
Hello guys,
I have some play in my drag link and some wobble over bumpy roads....is the drag link serviceable? i.e can the ball joint at the knuckle end be changed or do a i need a complete drag link? what about the steering linkage side? most kits i've seen at quadratec have only a new joint for the knuckle side....
thanks
Old 11-06-2012, 06:27 AM
Rob 12B1P's Avatar
The drag link is two pieces, niether are servicable. I recently bnought the upper and I think it was $35. Not sure about the lower (longer) part.
Rob
Old 11-06-2012, 08:28 AM
TheTerminator's Avatar
You need to buy the entire drag link (minus pitman arm side tie rod end and steering wheel adjuster) if you want to replace the tie rod end at the knuckle. Retarded design, if you ask me.
Old 11-06-2012, 03:11 PM
Sponsoring Vendor
chris@offroadevolution's Avatar
As mentioned you need to replace the bar
Quick Reply: Drag link servicable?
