Drain Holes?
Old May 3, 2016 | 06:55 AM
16FW's Avatar
Default Drain Holes?
I got into deep water a week ago, about an inch below the bottom of the door. None came in through the door gaskets, but the carpets are still wet. Are there open drain holes under the carpets? I don't see any way water could have gotten in otherwise.
Old May 3, 2016 | 06:59 AM
TheDirtman's Avatar
there are but you should pull the carpet and let it dry outside the jeep to prevent corrosion and mildew in a high humidity area like you live in.
Old May 3, 2016 | 07:13 AM
16FW's Avatar
You are right about pulling the carpet, but that is a big hassle. Since it hasn't dried in a week, I guess I better though.
Thanks.
