Driver's Side LCA hardware
Old May 5, 2008 | 07:08 AM
SilverBak's Avatar
Default Driver's Side LCA hardware
Long story short....My Bolt, Nut, washers, etc for the driver's side rear lower control arm is gone and I need a replacement. Does anyone happen to have the part numbers or can someone recommend the Grade eight sizes I need to go purchase at the hardware store? I would be tremendously appreciative!!!!
Old May 5, 2008 | 07:55 AM
WRAITHYJEEP's Avatar
ok i will tell you but you have to tell us how?
at the frame mount - bolt 06104266aa , - nut 06508598aa
at the axle mount - bolt 06104266aa, nut 06104719aa
these numbers may now be superseded but they will get u there
the parts catalgue doesn't get bolt & nut specifics
Old May 5, 2008 | 08:55 AM
SilverBak's Avatar
Ok, so you know how you are supposed to re-torque the blasted LCAs, trackbars, swaybars, etc shortly after doing a lift? Wel...ummm...err...I apparently waited to long for one bolt and nut!!!!!
