This is driving me crazy!
I'm not sure about it but I could feel a knock inside that joint when I went under the car and my wife was turning the steering wheel left and right. Ask someone to steer while you check.
Also I feel the knock only when I turn the steering wheel counterclockwise (left) after I turned it clockwise (right). If it was the joint in the shaft I think I would feel the knock either turning left or right, that is a splined joint and when a splined joint develops some play left or right should be the same.
Since I don't feel any knock in cold days and before the JK warms up I wonder if shielding the shaft from heat or installing a steering fluid cooler could work
Today I decided to check my intermediate shaft and collar again: I grabbed the upper intermediate shaft and tried to move it. It looked solid.
Then I did the same with the lower intermediate shaft (between the boot and the steering box) and I found some play in the joint between the shaft and the steering box !!!
I still don't know if it's due to the bolt that is loose (I don't have a wrench to get there) or to the C joint.
But I could feel the play and hear the knock each time I moved the shaft.
i have the same cluck/noise i think i have a bad drag bar end link... im going to replace that and see what happens.. also have the clunk in the steering shaft.. im hoping some greese will fix that..
Hmm, is that a set screw? Does it have an allen head? My 07' is different. It has a pinch bolt that squeezes the end together.
I get that clapping noise when I let up the clutch too. It's more obvious in 4Lo but it's been that way for a few years (I think since I got the jeep) and I've driven it 71,000 miles so far with no issue other than the annoying noise.
Does everyone else with a manual get this noise?
