DW trackbar
Remove the track bars and on each side of the track bar there are rubber bushings that the bolt goes through. Stick a screwdriver in there and pull a little. You will be able to see if the bushings are separating from the track bar.
At what mileage did you get death wobble? Is your Jeep lifted or did you change anything on it?
