egr
Old Apr 2, 2012 | 03:46 AM
jdavis883's Avatar
Default egr
Were is the egr at on the jks, I went to auto zone and they did not know were it was at, my check engine light is on, and the code says bad egr
Old Apr 2, 2012 | 03:58 AM
rob_engineer's Avatar
What year is it? Also, I think a faulty vacuum line can also give codes for bad egr. This happened on my daughters Mitsubishi eclipse. I found a hole in a vacuum line. Replaced it and the code went away.
Old Apr 2, 2012 | 04:33 AM
Chris333's Avatar
Its on the back passenger side of the engine near the top. Kind of a bitch to get to.
Old Apr 2, 2012 | 04:40 AM
JPop's Avatar
If you remove the inner fender wall it's much easier. A great tip from either ronjenx or markdorian. There should be a thread on it somewhere.
Old Apr 26, 2012 | 07:20 PM
jdavis883's Avatar
Thanks guys for the info, I found it and had it replace, somehow it was pluged up,
