Embarrassing Question....
Old Jun 24, 2007 | 01:44 PM
blndspt's Avatar
Default Embarrassing Question....
Guys,
How the heck do you zip out the back window? It doesn't appear to be a simple as unzipping the zipper. When I go to both sides, it doesn't appear that the zipper lets the window piece come off completely?
Boy I feel dumb about that one! ;(
Old Jun 24, 2007 | 01:56 PM
aristobrat's Avatar
Take the zipper on the right and unzip it all the way over to the left side so that it's on top of of the left zipper.
When the two zippers are on top of each other, you should be able to lift the back window up and out of them.
Old Jun 24, 2007 | 02:23 PM
jetsfan28's Avatar
The tip that helped me most is that the two zippers stay attached to the window... NOT to the top as you would expect.
Once the two zippers are on top of each other on the drivers side, it will take some pull to get the window out.
Old Jun 24, 2007 | 06:09 PM
Happened to me too....
Old Jun 24, 2007 | 06:18 PM
07JKX's Avatar
wait... is everybody NOT removing the bar that is held tight with the tailgate when they take the windows out??? does the vinyl just pop out of the bar so you can leave it in????
Old Jun 24, 2007 | 06:50 PM
dougolupski's Avatar
You shouldn't feel bad at all I own an 04 wrangler for three years and strugled like hell to get it out. They I stop turned away and it just came off. On the old models the zippers stayed with the top on the JK it goes with the window. That said the old ones you pull the window up on the JK you pull the window down. I damn near tore the window off. One thing I found that help is to pop off the drivers side top where it connects by the tailgate. Just pull out an inch or so and it helps going inand coming out.
Old Jun 24, 2007 | 08:21 PM
Rubimon's Avatar
You need to slide it out. I leave it on the window if I am just storing it at home. I take it off the window put it back on the tailgate if I am rolling my windows and taking them with me.
Also, a great way to store the windows in your garage is to get two of those spring clamps from home depot ($.99 ea.) and screw them to the wall. Stick all three windows in the clamp(by the fabric) and they hang there nice and flat.
Old Jun 24, 2007 | 08:47 PM
lightning's Avatar
Great idea...never thought about that and I was in the clamp section today at lowes (smacks self in head).
Old Jun 25, 2007 | 05:50 AM
berg's Avatar
I've been meaning to ask. What is the purpose of the double zipper on the back window? It doesn't seem to do anything.
Old Jun 25, 2007 | 05:53 AM
armycop's Avatar
You can unzip both sides up and roll up the window with the straps that should have come with the Jeep! It should snap to the soft top.
