Engine Acting Up?
I have an 09 X 6 speed and it's only got around 5700 miles and you know how when you are at a stop and it idles at around 900 rpms. Well every once in a while it will start to idle at around 600 rpms.
I took it to the dealer and I couldn't replicate it.
Is this bad? Everytime it starts to idle at 600 rpms I treat it as a stall and I turn it off and restart.
your's idles at 900 normally?
mine idles at around 600 normally.
I'm pretty sure it might have something to do with the eco system built into it but i can't find shit on it in the manual so i have no idea.
The first thing I would look for is a vacuum leak. High idle indicates that you have one. The normal idle speed is around 600-700 rpm. In your situation when the computer tries to idle it down then it wants to die. If you can't find a vacuum leak, I would check the EGR to see if it was sticking open a little.
