Engine Idle Shutter
Old Aug 24, 2010 | 07:16 AM
  #21
The Pirogue's Avatar
Originally Posted by azrwilkinson
I have this issue as well, chalked off to either the fan coming on or the ac compressor just cycling. Does it more the hotter it is outside. I also experience slight engine knocking. It could be an ignition timing issue in the ECM.
Hello all. New to the Forum. I am having this exact same issue. A combination of my warranty just going out and not having much time to diagnose a problem such as this I have my 07 6spd in the shop this morning getting it looked at. The shop owner/mechanic is a jeep specialist and should find the culprit. Why am I hoping he finds more than just the spark plugs needing replacement? They were "replaced" at the dealership a month ago with no change in the engine shutter. One time it was so bad I actually had to put my foot on the gas to keep it from dying. I will post updates once this is resolved.
Old Aug 24, 2010 | 12:06 PM
  #22
Just got the jeep back. was told the same thing thats mentioned earlier on this thread.
Technician: "I have to charge you $45 bucks for the time spent looking for something all JK's do. Has it ever stalled on you?
me: No
technician: "Doubtful it ever will. If it does call me"
And so I'm gonna stop chasin' unicorns and put it out of my mind. Goin campin!
Old Aug 30, 2010 | 09:03 AM
  #23
psultan's Avatar
Default Brought to dealer
I brought it to the dealer and they could not duplicate, surprise, surprise.
My regular mechanic said it was a transmission sensor. I have not tried that because I'm still under warranty and want the dealer to take the $$$ hit.
Old Aug 30, 2010 | 12:59 PM
  #24
07JK41Z's Avatar
yah same problem too, only does it every now and then, WTF?
Old Aug 30, 2010 | 07:34 PM
  #25
JKNIGHT's Avatar
mine has been doing this since i bought it..i just learned to live with it..
Old Nov 29, 2010 | 06:15 PM
  #26
mark9998's Avatar
I just scheduled an appt at the dealership today for my 2010 Unlimited for this same issue. I hadnt looked on here for anyone else also having this same issue until now. I seem to notice my shutter or engine hic up not only when at a stop light, but when I am going between 20-50mph and just giving it a little gas, not really accelerating. I already have about 25K miles and I just started noticing it maybe 5k miles ago.
Ill post back up with their "expert diagnosis" on Friday (just in case anyone wants a good laugh Friday afternoon).
Old Nov 29, 2010 | 06:20 PM
  #27
TexasTim's Avatar
Default Morning Idle
Mine does it nearly every morning once. Once it does it the first time it is usually done for the day. Maybe since it does it intermittently it could be a condensation in the fuel or even the intake. I wonder if those of us that are having this live in humid areas of the country. Just a thought......
Old Nov 30, 2010 | 03:05 PM
  #28
Tuto's Avatar
I agree with it being a Pollution/Emission control issue related to the O2 sensor (slow response and ECU programming)
For those of you going to the dealer have them check the
Service Bulletin Number 18-027-10
Group: Vehicle performance
Date: Oct 20,2010
Old Nov 30, 2010 | 04:20 PM
  #29
dsp's Avatar
dsp
Had this happen to the wifes Jeep, but we would get a code, first it was an 02 code, then a mult cylinder misfire.
Fixed crack in exhaust mfld., changed 02 sensors. changed wires and plugs. clean throttle body. finally took it to dealer, found cats were plugged.
They replaced them .under warranty.
Old Nov 30, 2010 | 04:40 PM
  #30
drumnatural's Avatar
Originally Posted by EarlyJk
Then what plugs are good replacements for our 3.8 engines?
NGK Iridium
