Engine knock
Dont feel bad. Mine is ticking too. I think it might have to do with the timing belt but im not going to rip it apart. Also i did run it almost dry one time. I think it could be i killed a hydro lifter. Myabe but who knows. Ive been running with the tick for over a year now. 15k+ miles and still offroad. no porblems. but i have made it a habbit to check the oil every time i put fuel in. I burn about a qt every 300k. not too bad but i do tow a 18ft boat around in the summer. I have been thinking about doing the oil pump but thats for another day. Im in vegas so every seal dies after about 2 years out here. I did both the pan seal and the drop down seal. pretty easy to do. You have to pull the pan first and then pul the drop down. No i didnt go spend money on a seal either. RTV that thing. let it dry for 20 mins or so then bolt it back on. No more leaks at all.
Yes the pans are quite easy. Almost stupid easy. It takes longer to scrape off the old gasket then anything. And you get a good look at the bottom end of your motor. Side note. I do have the 6 speed so there was a block between the motor and the trany I also had to remove. But that's it. Once you do the PVC valve hit me up. Odds are ill do that too. It's cheap enough might as well
Awesome. Im trying to think if there is any other problem i ran in to with the oil pan. Not really but depending on how you wheel and how many miles you have on your rig might as well change out the trany fluid too. Sucks that its 1.5 qts and its 23 bucks a qt from the dealer. But its quite easy. Transfer case is just ATF fluid, even easier. Front and rear diff you can do with out even pulling the cover off. I mean if your going to drop the pan and the seal is bad might as well drail all the blood out of the poor baby and fill her up with the good stuff too.
Hubby. If I remember correctly there is a how to guide that shows how to make a tool to get the plug out. I was swapping out the headers on mine when I changed it. Yeah I don't know who did that with the pipe but it's like they ment to. It sounds stupid but try aluminium foil and make a funnel out of it. Should work. Easy to throw away and should keep the pipes clean. Maybe a funnel of the right size might do it. This is one of those times to get creative I guess.
