Engine is misfiring...not throwing a code.
Old Aug 9, 2010 | 06:23 PM
Rugbyduck's Avatar
If I'm looking at that side there is the dipstick and then directly behind that is a plastic electrical connector...that the right thing? If so, how the hell do you get it out? I'm assuming it screws in?
Old Aug 9, 2010 | 06:24 PM
Rugbyduck's Avatar
Behind the tranny dipstick that is...
Old Aug 9, 2010 | 07:20 PM
Rugbyduck's Avatar
Ok, I found it...on the side of the block...right side...underneath the heatshield behind the cat.
Replaced it with another and STILL the same issue. Do I just need to drive it and have the computer relearn?
Old Aug 9, 2010 | 08:40 PM
ronjenx's Avatar
If you mean you found it on the right side of the engine block, you found the wrong sensor.
The crankcase position sensor is on the right side of the bell housing.
Old Aug 10, 2010 | 08:22 AM
Rugbyduck's Avatar
Argh...pics? I cannot find a pic anywhere!
Old Aug 10, 2010 | 08:46 AM
Rugbyduck's Avatar
According to this...see #4, I got the right thing.
Name:	Screen shot 2010-08-10 at 9.40.11 AM..jpg
Old Aug 10, 2010 | 01:18 PM
ronjenx's Avatar
Attachment 81093
I see #4, in the pic. Its location is unclear in the pic.
The item you suspect is the Crankshaft Position Sensor: Is it on the engine block, or on the bell housing?
I ask because the crankshaft position sensor is on the bell housing.
Old Aug 10, 2010 | 01:28 PM
Work in Progress - JK's Avatar
Most of what you are checking should throw a code, but one item that won't 'always' throw a code is a blocked injector. If you just changed engines (I think I read that) maybe you had some crap in the fuel line - have had this problem, let my tank go to 1/4 full and put in some injector cleaner and Heet to get any water out, run on the freeway for a few and could feel it clear itself.
Good luck - hope this helps?
Old Aug 10, 2010 | 06:31 PM
dsp's Avatar
dsp
check for a cracked exhaust manifold. this could cause your cats to become plugged.
