engine running rough
Ok, my engine is running rough (If feels as though its missing a bit.) so I changed the plugs and wires. That seemed to fix the problem for about 2k miles. Now its running rough again. I was thinking electrical because the spark plug and wires solved the problem for a short period of time. Anyone else experience this type of problem? Anyone of any ideas on what the problem is?
You should check the Ground cable on the Battery. Some people had problems because lack of ground on the electrical system. They solve the problem by addidng an extra ground.
Also check the throttle body and if it is dirty clean it. There is a write up about it.
ps.
Hope that you are not using E3 plugs.
ps.
