Esp bag light came on?
ESP Bag light
Do you mean your air bag light or your traction control light?
If it's your air bag light take it to the dealer as that light doesn't usually come on unless there is an issue....if it's your traction control light it could be many things but 9 times out of 10 it's just because a wind gust or larger bump wiggled the Jeep the wrong way and trips the sensor. My '10 Sahara used to do it all the time but would always clear after turning the Jeep off, so the dealer never showed any codes. I fixed it by disabling the traction control. Now the light is on all the time, but at least I know why.
BTW you'll probably get better responses to your threads if you provide more details about your problem
Do you mean your air bag light or your traction control light?If it's your air bag light take it to the dealer as that light doesn't usually come on unless there is an issue....if it's your traction control light it could be many things but 9 times out of 10 it's just because a wind gust or larger bump wiggled the Jeep the wrong way and trips the sensor. My '10 Sahara used to do it all the time but would always clear after turning the Jeep off, so the dealer never showed any codes. I fixed it by disabling the traction control. Now the light is on all the time, but at least I know why.
