Esp,bag, and traction control light on after going in to ditch full of snow.please he
Speed sensors in the Jeep are plug and play (they are held in place by a bolt and you merely unplug the old and plug in the new). There are even great YouTubes to see what you're up against. One thing about the Jeep is it is pretty user friendly. I have forgotten how more challenging other vehicles can be to work on.
These are the lights typically associated with the speed sensors.
Yeah, the discussions typically get confusing because 3 lights tend to always come on and the associated problems get mixed all together in the discussions but it really does matter which 3 specific lights come on. I even had to go back and edit my original response because I mistakenly said "ABS" instead of "Air bag" light.
I had to replace a speed sensor, and can confirm those are the 3 lights I seen. From what I surmised after reading a few hundred threads on 3 dash light problems is that if the red Brake light comes on, then that points to an ABS module or ABS electronic control module failure since those parts obviously control your brakes. If the Air Bag light comes on then that is typically a clock spring problem because your clock spring is assembled in the same steering wheel as your air bag.
