esp/bas
Old Jul 17, 2009 | 06:17 AM
PA RUBICON's Avatar
Default esp/bas
was driving this morning down a steep downgrade to make a right hand turn (a little aggressive) then "ding". the esp/bas and the car icon were all on solid. did my errands. then all lights were off (normal) on the way home. stock. wheel centered. had a flash done about a month ago for the esp/bas light being on. been fine ever since. did the hard turn/downgrade set off the esp? checked for codes to be safe. none.
Old Jul 17, 2009 | 07:01 AM
jkkat's Avatar
going too fast?????
Old Jul 17, 2009 | 08:05 AM
PA RUBICON's Avatar
Originally Posted by jkkat
going too fast?????
guilty . did it just kick the system on? did not feel any different.
Old Jul 17, 2009 | 09:20 AM
jkkat's Avatar
must hav3e been a combo of the esp system goofing on it, i get it when i try to flat track RubyDoo on gravel roads.
Old Jul 17, 2009 | 03:33 PM
Mariner's Avatar
sounds normal to me, happenens every day on the way to work theres a corner with a bump on it that i like to get a little air and light the dash up as everything turns on
Old Jul 17, 2009 | 03:58 PM
MetalNutz's Avatar
sounds normal. taking a corner like that most likely made you lose traction enough for your esp to come on
Old Jul 17, 2009 | 08:58 PM
Mr.ZAP's Avatar
yeah, and then the ABS likes to kick in (which is always freaky lol)
Old Jul 17, 2009 | 09:38 PM
JKMARINE's Avatar
It wears down the brakes too much for me so I threw a bypass switch in. If anyone is interested, here is a post I found:
"Once complete, when you want to switch the ESP you just flick the switch off. When you flip the switch the three lights on the dash will turn on and stay on until you turn your Jeep off and start it again. The ESP and ABS will remain disabled until you turn the switch back on, turn off and restart the Jeep.
Tools/supplies needed: wire cutter, wire stripper, razor knife, soldering iron, solder, couple feet of wire, drill, toggle switch, electrical tape.
*note* I soldered all the joints but you could use crimp style connectors if thats your cup of tea.
-First figure out where you are going to mount your switch and cut two pieces of wire long enough to run from the spliced joints to the.
-Remove panel below steering wheel. You really only need to do this if you are going to put your switch in the same area as I did.
-Locate the bundle of wires on the right side of the foot-well. Mine was not tapped up – If yours is, you will need to remove the tape using a razor knife or similar
-Locate the purple wire with a light blue stripe. (you will see another purple sire with a dark blue stripe so make sure you get the light blue one) There are several wires that are close, but you should be able to pick it out easily. Once you are confident you have the correct wire – cut it!
-Now is a good time to put the key in the ignition and turn it to the on position. If you have cut the correct wire there should be three lights that stay illuminated: esp/abs/the sliding vehicle
-Prepare the wire you just cut by striping and then tinning the ends with solder. Also, strip and tin the new lengths of wire you are going to run to the switch. Once you have them prepared, solder the wires together.
-Wrap the soldered joints with electrical tape.
-Drill a hole in the dash to mount the switch. Route the spliced wires through the dash and to the area you are mounting your switch. I mounted mine on the dash above the speaker. I’m not detailing how to get access to the back of this area as it’s easy to pull the vent out and pop of the side panel.
-Solder the wires to the toggle switch. The lead that is running towards the rear of the Jeep is attached to pin 1.
-Slide the toggle switch through the hole and put on the retaining nut.
-Put the Dash back together.
-I also wrapped the bundle of wires up with electrical tape because I wanted to keep my work tucked away so to speak"
Old Jul 18, 2009 | 05:00 AM
Chainsawjames's Avatar
Wait until you have to merge in a snowy intersection and the ESP/BAS cuts your RPMs while traffic is coming. Awesome!!! I never had a problem in my TJ to warrant such a device and believe me, I put it through it's paces. In my JK, I bypassed the whole thing with a switch. I am willing to bet the system has caused more accidents than it prevented. Completely retarded....
Old Jul 19, 2009 | 02:54 PM
PaulW's Avatar
I don't drive my JK much as its really my son's ride, but I have a Cherokee SRT8 and I was at a SRT8 track event a couple of weeks ago and the ESP saved my butt several times. I drove the Cherokee, Challenger, Charger, 300C and Caliber SRT vehicles and the ESP really works on the track. Its probably not helpful off road though. By the way, the Cherokee SRT8 is by far the best of all of the SRT8 vehicles. Nothing could touch it on the road course or the drag strip. SRT had over 40 2009 SRT vehicles at the event all with less than 2k miles on them and we got to beat the crap out of all of them. It was awesome!
