ESP and ETC warning lights flashing on dash
Old Apr 27, 2011 | 07:32 PM
08yellowx's Avatar
Take into the dealer and tell them about it, if you havent had it in to them for a while there is most likley a bunch of updates that your jk needs, being emissions related it should be covered under the emissions warranty.
Old Jun 1, 2014 | 09:51 AM
vegan_jeeper's Avatar
I had this exact same problem, and it happened almost daily. I finally found the fix - battery terminals! Check out the full fix on my blog.
Hope this helps!
Scott
Old May 18, 2021 | 11:30 PM
Griffin Buck's Avatar
Having this exact issue on my 2007 Jeep wrangler jk with the 3.8l v6. Already went down the rabbit hole of replacing; PCV valve, spark plugs and wires, coil pack, throttle body, crankshaft sensor, camshaft sensor, and a new battery. I’ve got no vacuum leaks and all the grounds are nice and snug. I’ve heard things about a clogged catalytic converter? Gonna loosen that up tomorrow as well as replace battery terminals. Any other ideas of what would cause this?
