Excessive heat/ESP help
Old Aug 12, 2010 | 07:36 PM
konen's Avatar
Default Excessive heat/ESP help
i have question on what forum do i post his in. i have alot of heat blowing on my feet when i am on the highway where is it coming from? i also have the esp light blink on me and brake on its own when i am going slow on winding roads. i turn it off but it still comes on.
Old Aug 13, 2010 | 10:58 AM
98jeepboy's Avatar
I hate to say it this way. But its the JEEP God telling you to slow down. Jeep is not a sports car. They sway in a corner and that tells the ESP to slow you down to not roll over. Thats why it goes BLINK. BLINK. BLINK. BLINK. It is the Idiot Light. An if your not lifted the you probally need to listen to what it is saying. To the heat, your driven it to hard if its building up on short runs.
Old Aug 17, 2010 | 08:03 PM
konen's Avatar
Default thanks for the help
it has a 4 inch lift but no one answered in the modified forum. does the lift and tires cause it too come on when it is not needed? really i am not driving fast at all trust me. and i was woundering at what rpm you shift at because i shift before it gets to 3000 rpm and i still get all the heat when i drive on the highway
Old Aug 17, 2010 | 08:41 PM
Fuzz 40's Avatar
You need to shut off the ESP as the lift and tires is causing your ESP to go crazy when you take turns. Due to the difference in wheel speed is is applying the brakes to correct your path causing the light to flash in your dash and the heat from the brake pads being used.
Here is how you disable it.
1. Place transfer case into neutral
2. Start Jeep
3. Turn steering wheel 180 degrees (jeep logo should be upside down) to the right and hold it in place.
4. While holding the wheel in place press and hold the traction control button in the center dash for 7 seconds.
5. Turn steering wheel to the left 360 degrees so once again the jeep logo is upside down and hold it.
6. hold the traction control button in the center dash for 7 seconds.
7. Re center the steering wheel and hold it there.
8. hold the traction control button in the center dash for 7 seconds.
9. Turn off the Jeep.
This should disable your ESP and stop causing the system to kick in every time you take a turn. When you turn on the Jeep it should say in the odometer ESPOFF if you did it correctly.
Old Aug 18, 2010 | 10:39 AM
Bradlybob's Avatar
Veteran: Navy
Did you recenter the steering wheel when you did the lift kit? If not, the computer is getting confused. It sees that the steering wheel is turned a certain amount yet the Jeep isn't turning the amount the computer thinks it should be so it's applying the brakes in an attempt to make the Jeep do what it's supposed to do according to the program.
Old Aug 29, 2010 | 06:50 AM
oregon signs's Avatar
my driver side floor cooks my feet on long drives.
