Factory fender flare rubbing on body and rusting?
Old Aug 22, 2011 | 10:48 AM
maine07jk's Avatar
Default Factory fender flare rubbing on body and rusting?
I noticed that my front factory fender flares are rubbing on the paint near the bottom and it's beginning to rust. Anyone else have this happen and what did you do to protect the paint?
Old Aug 23, 2011 | 03:42 AM
maine07jk's Avatar
Anyone????
Old Aug 23, 2011 | 04:07 AM
ClaytonT's Avatar
Mine are. Especially the one I knocked loose on a tree. I've cleaned it and used touch-up paint but no real fixes yet. I'm waiting to see if the ACE flares are gonna be released soon, then figure out a good pattern for Line-X.
Old Aug 23, 2011 | 05:55 AM
Vernnz's Avatar
How close it the rubbing to the brake lines? A while back there was a recall because factory fender liners were rubbing the brake lines. I looked at mine and the driver side had worn th eblack paint off the tubing. I cut a notch out of the fender. Next time I take it in for something I will have them log the recall as complete.
Are you the original owner?
Old Aug 23, 2011 | 03:00 PM
skibum's Avatar
When i took my stock flares off to install my Bushwhackers it was apparent that all four had rubbed the paint off to one degree or another. Some of it was through the topcoat and some was through the primer and rusting. Another brilliant design by our friends at Chrysler. I touched up everything then put a strip of clear adhesive backed plastic everywhere the flares touch the body........then I installed the Bushwhackers. No problems since.
Old Aug 24, 2011 | 04:32 PM
maine07jk's Avatar
I replaced one a while back and if I recall it was just a plastic clip you push through the fender.
Old Aug 24, 2011 | 05:36 PM
rickz's Avatar
i had same problem put new clips on bottom of flair through body and on top there is a bolt going up that has a lot of up and down play of the fender i put spacer on bolt so the fender would tighten up onw my fender holds tight no movement at all now
