factory mirrors
Old Apr 18, 2013 | 10:04 AM
lunchbx05's Avatar
Default factory mirrors
I am trying to get my mirror seprated from the housing that goes to the door but wont move at all. i sprayed wd40 and let it soak and still nothing. i removed the bolt underneath and try hittn with a rubber hammer still wont move. any ideas how to knock it loose
thanks
Old Apr 18, 2013 | 10:15 AM
Delux2769's Avatar
thanks
Twist it... You'll think it is breaking, but it will pop right up. It's one of those sketchy take-aparts.
Old Apr 18, 2013 | 10:17 AM
lunchbx05's Avatar
i never tried that i did push it in to bring closer to my jeep. i will try to do that this weekend. do you have to use alot of force when you twist it.
thanks
Old Apr 28, 2013 | 08:29 AM
lunchbx05's Avatar
i have tried everything in the world to try to remove my mirrors from the factory bracket but nothing works. i sprayed it with wd40 let it soak for couple hours came back and twisted and used a rubber mallet on the mirror and still does not move. i tried to use plyers below the mirror and still wont move. i even took a screwdriver and tried to tap it out from where the screw goes and still no movement. any one else have any ideas to get mirror off.
thanks
Old Apr 28, 2013 | 08:33 AM
rockyjk07's Avatar
The first time I took mine off I left the bolt screwed in a lil and hit it with a hammer they were stuck how you are describing just gotta use some force lol
Old Apr 28, 2013 | 09:00 AM
lunchbx05's Avatar
i did try leaving the screw in and tried to use some force still did not move. it has became a pain in my butt tring to get these mirrors loose
Old May 3, 2013 | 06:02 PM
kgonzalez's Avatar
I've got the same problem. I tried today and gave up after an hour with no luck. I tried hammering with the bolt partially out and it didn't budge. That was before and after twisting and turning while pulling upward as the instructions directed. Is there something I'm missing here too???
Old May 4, 2013 | 03:56 AM
metaldemon's Avatar
I am going to try and take off the drivers side tomorrow, because it rattles sometimes.
Old May 4, 2013 | 02:49 PM
caryfire's Avatar
I stood on my side rails and pulled with every bit of force I had.... Yes they came out, straight up and knocked my tooth out! Lol!
Old May 6, 2013 | 04:23 PM
kgonzalez's Avatar
Finally got it!! Hammering the bolt "popped" it free
