Factory Roll Bar not painted all the way.
Old May 11, 2011 | 04:20 PM
ramath0294's Avatar
Default Factory Roll Bar not painted all the way.
Hey
Today I took off my bar padding / cover and the two bars that angle down are painted like a blind guy did it drunk... You can see the primer or anti rust spray they put on before real paint its a 2010 JKU any body else have this problem I will try to put some pics up soon...
Old May 11, 2011 | 04:24 PM
zeppo's Avatar
Lots of guys have reported some weird interior paint schemes. roll bars like you some floor pans, it's a hit or miss kind of thing. I haven't removed my roll bar pads or enough of my carpet to thoroughly inspect. there are a few threads on it. if you mull your way through the zany search results you'll find something.
Old May 11, 2011 | 04:25 PM
suds's Avatar
Ya so do I I guess it's just a short cut. Who would think the car you buy should be fully painted
Old May 11, 2011 | 04:29 PM
GreenJK07's Avatar
Lol they only spray the areas that are exposed. Cheap way to cut corners....my cage looks the same. It's all random spraying.
Old May 12, 2011 | 07:02 PM
Dale36's Avatar
Yep, mine is the same way.
Old May 12, 2011 | 07:44 PM
TINMAN080's Avatar
All the same. Honda's, Accura's, BMW's, Benz, Caddy. All the same. Only the e-coat in covered areas. Won't hurt a thing.
Old May 12, 2011 | 07:49 PM
landoJEEP's Avatar
it does kind of ruin the 'all black' look I was going for, guess the padding can stay.
Old May 12, 2011 | 09:27 PM
tj_2010jk's Avatar
I bet if you were to bed line the roll cage it would look pretty good! Personally I don't like the roll cage matching the body color.
Old May 12, 2011 | 10:16 PM
Sahara_Maverick's Avatar
Mine is a 2007 Sahara and is the same. Paint only where it is exposed. I did not care because I do not plan to use it without the pads.
Old May 12, 2011 | 10:36 PM
fadeout's Avatar
rattle can solves all your problems.
