Fan trouble. get ride of the Elec fan and replace it with the mechanical fan
Ok, first off I am one of many that has some sort of fan problem and it is not covered by DC. I want to know if any one has done this yet. I am still in the research phase. I am going to get ride of the Elec fan and replace it with the mechanical fan off a liberty. I have talked with the local service manager and he is interested in it to. As every one knows the JK has alot of room up there. An be for someone says its going to take away power. I know that is a evil i am ready to take on. It is no more of a drain then when the elec fan is running in high with current drawl.
My questions Will the slip clutch form the liberty fit the JK Also does the fan shroud fit the close to the same as the jk |
see this thread, sport-atv put one on his but not sure how good its now working because I saw him after it asking about an aftermarket radiator for more cooling, maybe shoot him a pm or ask in that thread. I'd love to get rid of the crap fan too, I'm on my 3rd.
https://www.jk-forum.com/forums/show...t=61335&page=7 |
Originally Posted by 98jeepboy
(Post 978657)
My questions Will the slip clutch form the liberty fit the JK Also does the fan shroud fit the close to the same as the jk Why don't you look at a higher capacity aftermarket fan and avoid the hastle. |
I've heard Spal makes waterproof fans for motorcycles and vehicles but that dont make one specific for a jeep. I wonder if we could get them to if enough of us email them? OR find one of their universals that would work on our jeeps:dontknow2:
spal.com/default.php?t=site&pgid=39 |
well is there anyway to seal the elec stock fan. that would be the cheapest and better option i think.
Mine is not so much shorting out from water. I does not come on in any other mode then high. The guys at the jeep place say that they ran the test and high is working. I just wanted to strangle him after that. I had told the low was not working at all. 2 hours later, it was dumb luck it started working again. Now it seems to back in high mode only. That link has helped. I really am thinking of doinig that and useing both. I have over heated the trans in mine do to no air flow. Had top and doors off. i know it never came on till DING! An it came on and did not stop for about 15 min. An to the AC it neve cycles and pull air over the Condensor. I posted about this be for.
(Post 978835)
If I were you I would take it to a different dealer and get it fixed right. |
Just wire a switch to turn it off when crossing water.
Originally Posted by saltman
(Post 979212)
Me personally I would never remove my electric fan. to many benefits. ex. when in traffic the electric fan will keep the system cool unlike the clutch fan when the motor is at idle the fan is not really doin much to keep the system cool. Same with crawling rocks you need that fan to keep as much cool air flowing as possible. A Clutch fan just will not be a ble to keep up. Also being that the JK's gauge cluster is limited on temp readings you are taking a huge risk of overheating and not knowing about it till its too late... As you already know you will be loosing horsepower by doing this as well and that is something the JK's can not afford to loose.. |
Originally Posted by whpony96
(Post 979250)
That is the correct way to resolve this issue.. So IF you get the Libery fan mounted how are you going to tell the computer that it's not there anymore. This could be monitored by the Canbus System.
Me personally I would never remove my electric fan. to many benefits. ex. when in traffic the electric fan will keep the system cool unlike the clutch fan when the motor is at idle the fan is not really doin much to keep the system cool. Same with crawling rocks you need that fan to keep as much cool air flowing as possible. A Clutch fan just will not be a ble to keep up. Also being that the JK's gauge cluster is limited on temp readings you are taking a huge risk of overheating and not knowing about it till its too late... As you already know you will be loosing horsepower by doing this as well and that is something the JK's can not afford to loose.. The OP also said its not from crossing water. I've read his older posts about his fan problems. He really needs to just get the electric fan fixed right by the dealer. |
