A few questions
Old Oct 26, 2008 | 03:44 PM
KA3PIT's Avatar
Default A few questions
1- like most I have a leak somewhere...I had alot of water after a big rain
{ I pulled the carpet of course it was under water }
{I took the top off and put it back on incase that may have been a prob}
{Washed it and put a hose to it and NO WATER IN THE FLOOR}
{ I did get a small amount @ the top of the door not much but I was blasting it so I think that's not bad.I of course got the channel of water come crashing down when I opened the door.
My question
So I don't think I should take it to the dealer or should I?
2- It seems to me the steering has a little clunk once in a while,any ideas?
{ I had a GMC that did that and they had to repack the steering box,not sure if this is the prob or not any ideas?
3- I have a squeek when I shift and thought it was my clutch but I think it's something else,you can push the clutch and it is fine but when moving and you shift it has a squeek... whats up
4- does the jk have anything that needs grease or any fittings ?
Should I take it in ?
Old Oct 26, 2008 | 04:22 PM
BaltChief's Avatar
Take it in....there is a TSB on the squeeky clutch, the clunk is addressed in threads on here but you just as well have them fix it. I also think getting documentation is a good thing for your other problems as they may be able to help a bit on the leak.
Old Oct 26, 2008 | 04:30 PM
rickc309's Avatar
I had my hard top repaired after finding leaks last winter, I went through the carwash today and it's leaking again. Back to the dealer...
Old Oct 27, 2008 | 02:47 AM
amt97's Avatar
The steering clunk is well-documented on this forum, but I have yet to see a TSB from Chrysler with a fix. Just search "clunk in steering" or "steering wheel clunk" on this forum and you'll find several threads addressing this issue. Good luck!
Old Oct 27, 2008 | 03:15 AM
SLeepY_BoY's Avatar
its a jeep thing
Old Oct 27, 2008 | 04:17 AM
2008x's Avatar
Just my two cents worth but it's new, under warrenty etc.etc. If its not a hassle (my dealer loans me a car) I would take it in. They were able to fix my leaking top, I had to take it in twice (left the carpet out for about a month waiting for it to rain) Now have no leaks or any other issues. (for now)
Old Oct 27, 2008 | 04:18 AM
Lorrel's Avatar
I agree with all the posters who said take it in.
The more documentation now is better for future visits.
