Finaly fixed the dry start up knock
Old Dec 6, 2011 | 08:00 AM
Stillmotion's Avatar
where are you buying from?
linkie link?
Old Dec 6, 2011 | 08:04 AM
Roadrash's Avatar
Originally Posted by efan450
I'll just chime in and say my jk has 70,000 on it..it does burn about 1 quart every 3000...I've never had a startup knock but I've always used purple..5-30 since I bought it with about 55,000 miles on it, and i switched over that same weekend. Also I have always used wix filters.
Holding the pedal to the floor for a few seconds during cranking will not start the Jeep as soon and will help prime the system if you are having start up knock, I know its not the ideal fix but its better that that no lube momentarily in freezing temps!
How does this prime the system? What are you talking about?
Old Dec 6, 2011 | 08:05 AM
efan450's Avatar
linkie link?
I buy from my local distributor..my dad and I both run royal purple...I'm pretty sure you can go to there website and find local dealers...my dealer comes right up to my workplace and drops it off for me!
The downside is it isn't cheap...you can get better pricing if you buy by the case but if you walk into an auto parts dealer its just under 10 bucks a quart
Old Dec 6, 2011 | 08:07 AM
efan450's Avatar
Holding the pedal to the floor...the Jeep won't start, by it cranking a few more times before it fires will give the oil pump a chance to fill your filter back up if you have a faulty drain back valve, and get some oil to the top end before it actually fires.
Old Dec 6, 2011 | 05:38 PM
Pilot's Avatar
I had that knock on my 2011 JKU with 13,000 miles. Hoping it continues and gets worse.....
HEMI!
Old Dec 6, 2011 | 08:19 PM
Boom's Avatar
Great news! Like the OP, i have spent about $150 in oil and filters trying to find that magical combo to cure cold start knock. I know mine is not ABD valve related, because i have spun my filters off before starting and they are full. I think it is a combo of viscosity and filter flow performance.
Looking forward to going purple!
Old Dec 7, 2011 | 02:28 PM
ranjr's Avatar
Originally Posted by Ario56
I'm confused as to how this will help. I'm not trying to be an ass, I just can't think of how it would start any differently.
Maybe he has an electric oil pump.
Old Dec 7, 2011 | 02:37 PM
Boom's Avatar
I think what he means is that by holding down the pedal while cranking, it will not fire right away(computer prevents it), but will pump oil up top while the engine is under no load. When it starts after a few seconds, there is no knock because the engine got primed before it fired. The pump pumps oil as long as the engine is being cranked over (it's mechanical pump) so when it does fire, it is already primed up top, so no knock.
Old Dec 7, 2011 | 03:46 PM
ranjr's Avatar
You got that from this:
Originally Posted by Spinall4
Also I notice what helps is you turn to on position and wait till the beeping stops then starts it. Start it like a diesel truck
Old Dec 7, 2011 | 03:50 PM
Boom's Avatar
Ha ha no. From the post that says to hold the gas pedal down when cranking it over.
