Fixing blend box door
Is it difficult to fix the heater blend box door yourself? I'm cursed with the cold on driver side, hotter than the fires of hell passenger side problem that seems to be plaguing alot of JK owners. It's out of warranty, and I really don't feel like paying the dealer a $1000 to fix a stupid little part. If I can do it myself that would be great.
If you get the shop manual you can do it if you have time to spend on it. Not much fun from my experience working on Ford climate control boxs. Maybe the Jeep has it setup better.
The hard part is getting the HVAC out of the dash.
Originally Posted by kb1
(Post 2348754)
good luck and let us know the results.:beer: i just found the link.....hxxp://heatertreater.net/........(replace xx with 'tt' |
I have a vacation coming up, so I can mess around with it . I know it's the blend box door/gate. It's absolutely ridiculous to have this kinda problem. Hopefully it's not a major pain to get it fixed. Just looks like you have to tear your dash apart. Should be fun :crazyeyes:
(Post 2349265)
(Post 2348754)
Originally Posted by genesbro
(Post 2351345)
Spoke with a dodge tech about this and he said if the ac system does not have the proper amount of r134 it will act just like that. So you might have the system checked for proper charge before tearing it apart.
I am having this problem right now, my ac blows hot on the driver side and cool on the passenger side. I will post back with what I find out. Going to check coolant charge first then look into the blend door.
Got my ac fixed, turns out it was just low on coolant, recharged it myself for $30 and now its cold as ever. Also it looks like the blend door on the 07s anyway are a mechanical linkage not a motor.
