Fluid dripping from muffler
Old Apr 13, 2008 | 03:33 PM
SUBIGON's Avatar
With most vehicles it take about ten miles or ten minutes to get the exhaust system up to temp, to burn off all of the gases and moisture when you shut down. Watch some other vehicles some time and see them start their cars and let them idle for a minute and the condensation (water) will drip out of the rear tail pipe.
What you are seeing is normal condensation following a short run , that didn't warm up the whole exhaust system enough to expell it as a gas/steam.
As a side note that ten mile or ten minute rule also applies to recharging the battery after a start.
Old Apr 13, 2008 | 03:57 PM
TINMAN080's Avatar
Thumbs up
x2 absolutely correct
Old Apr 13, 2008 | 04:34 PM
dyolfknip's Avatar
Originally Posted by Suffolk JK
A guy shows concearn and people become asshats. I just don't get it.
I bet you are a blast at parties.
Old Apr 13, 2008 | 04:38 PM
mkjeep's Avatar
Remember to grease that fitting on your rims, it helps keep the muffler lubed
Old Apr 13, 2008 | 04:43 PM
jeepcanoe's Avatar
Originally Posted by tgrt
Don't worry about it. The factory probably just overfilled the muffler fluid. They do that pretty often. My guess is that you took a corner or two fast or sharp enough to make it leak a little. It'll work itself out in time.
muffler fluidI almost pissed myselfme
Old Apr 13, 2008 | 05:09 PM
tgrt's Avatar
Former Vendor
Oh my, I almost forgot about that! I'm going to run out to the garage and do that now.
Old Apr 13, 2008 | 06:46 PM
RedneckJeep's Avatar
It has a drain hole somewhere. Most all modern mufflers do. As mentioned in a couple of the serious answers, condensation builds up in the exhaust. It needs somewhere to go. If you get under it, I can almost promise you that you'll find a very small hole in the muffler. It's a factory drain.
Old Apr 13, 2008 | 06:57 PM
mkjeep's Avatar
Yep, has a drain and fill just like the differentials
Old Apr 13, 2008 | 07:23 PM
jeep08ham's Avatar
I love the humor! This always concerns a lot of people but there is a very clear reason why it occurs. First when the exhaust is cold and started the exhaust stream hits the catalytic converter where it is brought back closer to the base elements we have in air. Oxygen, nitrogen and some H2O. What you are seeing is the H2O that is visible until the exhaust warms enough and then it is steam. You will notice on a cold morning cars spewing steam from the tailpipe until the exhuast gets completely warmed up. Then it fades away and becomes invisible to the eye.
Do not worry about it as it is in all modern vehicles that run on gasolene. Or at least more previlent on Gas that Diesel engines.
Old Apr 13, 2008 | 07:34 PM
sgmrock's Avatar
Yeah, the drain hole is right where you saw the water coming out....really.
Muffler fluid...ha, everyone knows its ID10t liquid...
