Fog lights add-on
one wants the factory JK fog lamps...you buy a bumper cover with the holes to accomodate it...you buy the fogs...now, do you get with the fog purchase, the factory stalk for the turn signal to accomodate the fogs, or can you buy it separate, and if yes to all of the above, what is the install procedure?
The aftermarket mopar fogs for an X (oval ones), come with absolutely everything you need and with instructions. This is about $225 or so.
But if you want the round ones, you need to somehow get the bumper cover with fog holes (or other bumper), get the fog lights, and then get the kit from above to make it like factory or wire it yourself with a separate switch. (I'm going from memory here, but the bumper cover alone is around $215 I think, the fogs are about $200 EACH one, and again, the kit to make it factory is $225 or so, but going this route leaves you now with two extra oval fog lights.)
So, if you want the round ones, I suggest hunting down a bumper cover and the fogs from people on the forum. You can probably get both for anywhere from $50 to $200 (Instead of $600 or so new from factory). Then buy your own switch and wiring harness (I paid less than $20 for both), and wire it up yourself.
The install depends on which route you take. Hope this answers your question.
https://www.jk-forum.com/forums/jk-show-tell-33/%2445-off-road-driving-lights-11339/
