Found a Unused plug underneath my shifter cover!
Old Aug 2, 2010 | 04:36 PM
arasco85's Avatar
exactly. if u had a auto that wire would plug for you o/d. but since u dont have o/d the wiring just sets there. i would ASSume
Old Aug 2, 2010 | 04:40 PM
08YELLO-RUBI's Avatar
Originally Posted by Serg5000
Like stated above, put a meter on it and test the voltage. Then you will know what you can or can not do with it.
thx serg, going to test it tomorrow! I see ur from palmdale, I hope the brush fires didnt effect you!
Old Aug 2, 2010 | 04:48 PM
Serg5000's Avatar
Not at all, the fires were about 8 miles away and on the other side of the freeway. We were good.
On a side note, I know a test light would tell you if there is power. I never use them. I use a meter so I now exactly whats coming out of what I'm testing. Nothing wrong with a test light, I just don't use them.
Old Aug 2, 2010 | 04:55 PM
I'm going to use my friend's test meter! I'm thinking if I have a good source of power what do i want to use it for, so many options(i think)!
Old Aug 2, 2010 | 04:59 PM
Loadbreak's Avatar
There is lighting there, in an Auto the PRND21 lights up next to the shifter. So if may be either lighting or OD. Use a Test probe or Multi-meter and let us know what you found.
Old Aug 2, 2010 | 05:00 PM
ronjenx's Avatar
That's a good policy.
In today's vehicles, a test light is equivalent to a direct short, if the circuit was not for powering a light.
Even using an old analog volt meter can be bad.
High impedance digital is the safe way to go.
Old Aug 2, 2010 | 05:06 PM
Vernnz's Avatar
My Auto indicates on the dash. The center console is so dark I did the HVAC LED and cupholder LED mods. And it's not a burned out bulb. I have had the entire console out and there is no wiring for illumination.
Old Aug 2, 2010 | 05:12 PM
dmhines's Avatar
I've never been in an Auto JK .. but if there are no lights down there then the O/D switch makes sense. If that is the case ... it is merely gonna be a CANBUS +/- connector there ... and pretty much useless for anything ...
Old Aug 2, 2010 | 05:14 PM
Loadbreak's Avatar
My '09 X 2 door lights up at the console. I don't think it says on the dash at all...Wierd.
Maybe an option thing?? Mine is a base model..vinyl seats and all. 2 options Air and Auto.
Time for the Multi-meter !
Edit: Just checked again, the PRND21 lights up with the dash lights on mine.
Old Aug 2, 2010 | 05:16 PM
Brashanic's Avatar
meter yes. test light.....probably not. test light can cause problems on a can-bus
