freedom top question
Old Mar 26, 2013 | 02:30 PM
2K11BCJK's Avatar
Default freedom top question
is it possible to just run the front two pieces on the top? i want a bikini top but i also like the idea of maybe having a hard bikini like top if its possible to run the front parts an not the rear. anyone out there try this? it seems viable due to the fact the fronts screw down to the rollbar
Old Mar 26, 2013 | 02:57 PM
sitkojm's Avatar
Yup. On the back of the two panels, there is a black piece of plastic, just fold that down before sitting the panels in the roll bar, this will align them properly and make the sit flat. Just make sure you attach all the hold downs in the front/middle and definitely make sure you use the two screws/bolts to secure the panels to the roll bar.
Old Mar 26, 2013 | 03:43 PM
2K11BCJK's Avatar
thank you so much! i kinda thought it would work, just wanted to ask before i attempted it, the alingment tip will be great!
Old Mar 26, 2013 | 04:21 PM
sitkojm's Avatar
No problem at all, anytime, can't wait to take my top off!
Old Mar 26, 2013 | 04:33 PM
Ryan0260's Avatar
X2. Make sure the tabs are out, or they won't tighten properly, and you can strip out the bolts. I run mine like that in the summer if rain is in the forecast. It has saved me more than once.
