front coil help!!
just lookin under my 2007 unlimited sahara checking things out and i notice that my driver side coil spring is a 17 and my passenger side coil spring is a 18!!! what the hell?! im about to put a teraflex bb witha 3/4 added on top and now i feel like it will look wierd with two different but idk i cant tell now, any info or suggestions or if you know anyone that wants to sell on 18 oem front spring send them my way!
My front two were different too on my 2007 sahara. Had a 16 and a 15, did a leveling kit and it looks fine. Not sure why they were different. Bought a rubi set from a guy with 2008 set and they TOO were different.
"Jeep lean". The passenger side is lower, gas tank. Higher
number spring means it is a bit stiffer, a bit taller.
When getting new springs, set up right on level floor,
the one that might be a bit taller should go on the passenger
side, to help correct, "Jeep lean".
