Front Drive Shaft question?
Old Oct 23, 2013 | 07:11 AM
Deasoninc's Avatar
Default Front Drive Shaft question?
I have a 2011 JKU Rubi and I need to replace my front driveshaft. I am able to get a new takeoff one off of a 2012 JKU . Will this work in mine?
Old Oct 23, 2013 | 07:22 AM
kh202's Avatar
Front drive shafts are the same length in all JK's i believe, regardless of 2 door or 4 door. Rear driveshaft length is different between the 2 and 4 door, but the year doesn't matter.
Someone please correct me if I'm wrong.
Old Oct 23, 2013 | 07:31 AM
ChesterJFK's Avatar
My buddies 2010 manual rubi was shorter than my 2013 auto sahara.. But he said it fits, but his control arms are also a bit longer...
Old Oct 23, 2013 | 07:49 AM
kh202's Avatar
Measured on the Jeep? They aren't a fixed length.
Old Oct 23, 2013 | 07:57 AM
Sahara Lee's Avatar
Default Got the shaft?
Based on MOPAR driveshaft part numbers there are 5 different drive shafts for the front...
52853317AC fits
07-11 Wrangler & Wrangler Unlimited JK with Dana 30 Front Axle & Automatic Transmission
07-14 Wrangler & Wrangler Unlimited JK with Dana 44 Front Axle & Manual Transmission
52123551AA fits
12-14 Wrangler & Wrangler Unlimited JK with Dana 30 Front Axle & Automatic Transmission
52853319AC fits
07-11 Wrangler & Wrangler Unlimited JK with Dana 30 Front Axle & Manual Transmission
12-14 Wrangler & Wrangler Unlimited JK with Dana 44 Front Axle & Automatic Transmission
52853325AC fits
12-14 Wrangler & Wrangler Unlimited JK with Dana 30 Front Axle & Manual Transmission
52853321AC fits
07-11 Wrangler & Wrangler Unlimited JK with Dana 44 Front Axle & Automatic Transmission
If you think that's confusing, there are 7 choices for the rear driveshaft!
68022101AD for
07-14 Wrangler Unlimited JK 4 Door with Manual Transmission & Command-Trac 4WD
68022102AD for
07-11 Wrangler Unlimited JK 4 Door with Automatic Transmission & Command-Trac 4WD
52123558AA for
12-14 Wrangler Unlimited JK 4 Door with Automatic Transmission & Command-Trac 4WD
52853346AB for
07-14 Wrangler Unlimited JK Rubicon 4 Door with Manual Transmission & Rock-Trac 4WD
52853338AD for
07-11 Wrangler Unlimited JK Rubicon 4 Door with Automatic Transmission & Rock-Trac 4WD
52123557AA for
12-14 Wrangler Unlimited JK Rubicon 4 Door with Automatic Transmission & Rock-Trac 4WD
Good luck!
Old Oct 23, 2013 | 07:59 AM
DanNEBTD's Avatar
Rubis had D44 in the front, X's have D30 . . I dont know about Saharas (THough it was D30? May mean shorter shafts . . .
