Fuel Gauge Issue
Since I've had my JK, it seems that the fuel gauge has always seemed to be kind of random about how much gas I actually have.
For instance yesterday I went out with some friends, and when I left I was just under a quarter of a tank. My JK was on flat ground the whole time it sat.
Later when I went to leave again it was back right on a quarter of a tank, and stayed there until I got home, which is a 40 minute drive.
This morning, I get into my Jeep, start it up and the needle on the gauge doesn't move but 2cm it seems. In other words I went from a quarter tank of gas, to completely empty on my way home? This has happened a lot, and I run in 6th gear 95% of the trip home so there's no way I'm consuming a quarter tank of gas on one 40 minute trip, which is about 30 miles or so give or take a mile or two.
Anyway, I'm not sure what causes this to happen other than the floatie in my gas tank isn't positioned right, but I just got a new tank in a couple of weeks ago and this issue was apparent before I got my tank replaced as well.
Any thoughts? I don't like starting my Jeep up on empty and hoping I make it to the nearest gas station before it dies on me..
Just for sh!ts and grins, do an Actuator Test, and watch the gas gauge. This will tell you if the gauge is capable of pointing to the correct position, based on a given input.
Do it when the gauge seems to be alright, and again when you suspect it is not functioning correctly.
ACTUATOR TEST
The instrument cluster actuator test will put the instrument cluster into its self-diagnostic mode. In this mode the instrument cluster can perform a self-diagnostic test that will confirm that the instrument cluster circuitry, the gauges and the indicators are capable of operating as designed. During the actuator test the instrument cluster circuitry will position each of the gauge needles at various calibration points, illuminate each of the segments in the Vacuum-Fluorescent Display (VFD) units, and turn all of the indicators ON and OFF again.
Successful completion of the actuator test will confirm that the instrument cluster is operational. However, there may still be a problem with the CAN or LIN data bus, the Powertrain Control Module (PCM), the Totally Integrated Power Module (TIPM), the Controller Antilock Brake (CAB), the All-Wheel Drive Control Module (AWDCM), the Occupant Restraint Controller (ORC), the compass module, the Sentry Key REmote Entry Module (SKREEM) (also known as the Wireless Control Module/WCM), or the inputs to one of these electronic control modules. Use a diagnostic scan tool to diagnose these components. Refer to the appropriate diagnostic information.
1. Begin the test with the ignition switch in the OFF position.
2. Depress the odometer/trip odometer switch button.
3. While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the ON position, but do not start the engine.
4. Release the odometer/trip odometer switch button.
5. The instrument cluster will simultaneously begin to illuminate all of the operational segments in the VFD units, and perform a bulb check of each operational LED indicator. The VFD segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back. If a VFD segment or an LED indicator fails to illuminate, or if a gauge needle fails to sweep through the calibration points and back during this test, the instrument cluster must be replaced.
6. The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test. The actuator test will be aborted if the ignition switch is turned to the OFF position, or if an electronic vehicle speed message indicating that the vehicle is moving is received over the CAN data bus during the test.
7. Go back to STEP 1 to repeat the test, if necessary.
ACTUATOR TEST
ACTUATOR TEST
ACTUATOR TEST
I tried this and everything worked like it should. But my gauge still reads empty all day every day
Oh my gawd! This worked and reset my wonky fuel gauge. Thank you so much for posting this little gem. I can't imagine what a dealer would have charged to 'repair' the gauge that got wierd after a dead battery event.
