"GASCAP" warning came on
Old Nov 22, 2010 | 10:02 PM
Default "GASCAP" warning came on
I went wheelin with some friends a few weeks ago and a couple days after the trip a "GASCAP" warning came on where the odometer is. The gas cap is definitely closed and I've filled up a few times since then and still have the issue. I tried disconnecting the battery and plugging it back in, and it worked at first, but the warning came back. I looked underneath briefly and didnt find any loose hoses or cables. And the EVAP canister seems to be in good shape still (wasn't sure if that had anything to do with it).
Has anyone had any issues with this after a wheelin trip? Like I said, I haven't fully investigated it but wanted to see if anyone knew where to start looking so I have an idea of where to start.
Thanks,
Jared
Old Nov 23, 2010 | 02:58 AM
wvax101's Avatar
Thanks,
Jared
It's the evap canister check the hoses. One might be kinked a bit
Old Nov 23, 2010 | 10:58 PM
BigBruce's Avatar
How many miles you got on it? 'Cause it might be something a bit more serious. I was on a road trip about 8 hours from where I used to live in Colorado to another part of CO when my gas cap light came on and stayed on. I figured it was loose, but it wasn't... messed with that several times... then my check engine light came on.... when I finally reached my destination I immediately had a shop do a diagnostic on it. Turned out to be the EGR valve. Had to have it replaced. Could be a similar situation... could not be... good luck
Old Nov 25, 2010 | 08:45 AM
It only has 46K on it. The check eng. light came on shortly after the gascap warning came on so this could be it. Ill have it checked out soon. Thanks for the heads up!
Old Nov 25, 2010 | 01:19 PM
Dirtydog4x4's Avatar
Sponsoring Manufacturer
Had the same problem with mine. Check your engine codes. I had 455 and 456 show up on mine. Dealer had it three times before they found a hose at the top of the fuel tank was leaking.
Old Nov 25, 2010 | 02:25 PM
dr.gonzo's Avatar
Had the same thing happen to me. Turns out i left the gas cap off when I was trying to get out of the gas station before the crackhead hit me up for cash After replacing the cap down the street, the "gascap" warning was still there. I checked and rechecked the cap, the hoses, etc.
I fully realize this sounds ridiculously obvious and simple, but I finally cycled thru the odometer menu (odometer, trip A, trip B), and when it came back around to the odometer setting, the "gascap" warning was gone.
I'm sure you've covered that procedure, but sometimes the most simple solution gets overlooked so I thought I'd mention it.
Good Luck
Old Nov 29, 2010 | 05:49 AM
Kip Randal's Avatar
Post
I started getting the "GASCAP" message this weekend. I checked to make sure the cap was tight and cycled through the computer messages (i.e. Trip A and Trip B, etc.) but the message didn't go away. Took the Jeep into the dealership this morning and as luck would have it the message didn't come on. They checked the computer history and didn't find any record of the message but did find that there was an upgrade to my engine software so they installed the update. So far today it's not reappeared. If there is a problem it shouldn't be because of the Evap Can since the Jeep is only 7 months old, never been off road and has just barely 5000 miles. The guys at the dealership were very helpful so I'll just keep my eyes open for the message to reappear and my fingers crossed that it won't.
Old Nov 29, 2010 | 03:08 PM
jhiero's Avatar
do a search for this I had the same problem and the dealer said something about a switch that had gone bad.I cant remeber the name of the switch but they d\said they had seen a few with the problem. Mine went away after a few fill ups
