Getting traction control and ABS error lights
Hello
a couple of months ago I started getting both the traction control and the ABS light
when you goto take off after a couple of seconds it will lose 80% of the power for maybe 3-4 seconds
The error codes are all for the left rear...
the shop has replaced all of the ABS sensors and no change
they swapped out the left rear with the right rear and the problem stayed with the left rear
even replaced the bearing because there was a bit of wiggle room
his is on a Dynatrac D60 but I believe the problem s not in the axle, but I could be wrong
any help would be appreciated...we've consulted with Dave at Northridge and he's ben helpful, but we are running out of things to check,test or replace
matthew
matthew
