Grinding gear
Old Feb 26, 2014 | 06:55 PM
alects's Avatar
Default Grinding gear
My jeep came with a really nasty surprise-a grinding gear. Whenever I shift into 4th gear going downhill my 4th grinds. It's only 4th gear and I think it only happens downhill. What could this be? And I only have 18-19k miles on my jeep (bought it with 17k) so would the warranty cover the fix?
Old Feb 27, 2014 | 04:34 AM
familytime's Avatar
JK Forum Regional Rep
You bought it used from a dealer,warranty it
Old Feb 27, 2014 | 12:02 PM
jeepmojo's Avatar
Default sounds like
synchronizer issue in tranny not meshing gears correctly
Old Feb 27, 2014 | 07:18 PM
alects's Avatar
Thanks guys, that's what a few friends thought too. Hoping the warranty covers it!
Old Feb 28, 2014 | 10:12 PM
jeepmojo's Avatar
Default it will yes,
defect from the factory
Old May 13, 2014 | 06:43 AM
alects's Avatar
Finally got it fixed. Wasn't a synchro, it was the insulation between the cab and the shifter. The modified the insulation and replaced the shifter spring with a stronger one which is very nice. All covered under warranty
Old May 13, 2014 | 08:37 AM
jeepmojo's Avatar
Default yeh i should hae said that first
they try that if it still persists its syncros generaly the spring and boot is not the issue , but Chrysler has them do it anyway , seeing the orginal spring was weak to start with and the boot was to stiff . that did not work for mine it was syncros
