heater not working
Old Mar 15, 2009 | 08:22 PM
pooswa's Avatar
Default heater not working
wont blow hot air...just cold air comes out
Old Mar 16, 2009 | 12:40 AM
kane516's Avatar
Take it right back to the dealer?
Both of my TJs had issues with the heaters, the switches went bad. I didn't have a darn warranty on them unfortunately.
Good luck!
Shellikins's Avatar
I think I've heard that this is a problem with the water pump... (correct me if I'm wrong...)
No heat is rare in JKs. My heat will melt your face off! LOL.
Good luck!
Old Mar 16, 2009 | 03:18 AM
RedneckJeep's Avatar
Check the coolant level.
Old Mar 16, 2009 | 03:42 AM
Yoda's Avatar
Good luck!
No, if the water pump is not working, the engine would get very hot.
There is a small radiator for the heater, the coolant goes inside this radiator through a small valve. The cable of this valve is broken. Easy to fix.
Old Mar 16, 2009 | 04:27 AM
seer1's Avatar
There's a cable that runs from the heat control to an arm on the driver's side. My dealership doesn't even question it because they've seen it so much. Take it back there for repair.
