Help
I've noticed my front drive shaft making noises in 4wd. Exspcially while in 4 lo. I can rotate the front driveshaft by hand about 1/4 to 1/2 an inch. Any ideas. Can it be u-joints? I'm taking it to stealership it's under warranty But I'm not off till Friday! Pls help.
Have you crawled underneath to take a look at it? Ripped boot with a bunch of grease spitting out? A ring of grease on the undercarriage above the joint?
The front driveshaft is always spinning, regardless of being in 2wd or 4wd. If it is making noise, pull it off until you can get it replaced...
