Help
Old Aug 23, 2011 | 05:18 PM
tncruiser's Avatar
Default Help
What is the blk plastic cannister approximately 8 x 11 x 2.5 inches with two hoses attached near rear axle and transfer case. Does it hurt to operate it with a hole in it???
Help
Old Aug 23, 2011 | 05:23 PM
dcharge74's Avatar
That's your evap canister. It's part of the emissions control system. You can drive with a hole in it, or without the hole cannister for that matter. You will probably get a DTC on the instument panel though. Go to the dealership and buy a new one. If I recall correctly, they don't cost that much. Maybe $60 or so. Replacing it yourself is pretty simple also.
Old Aug 23, 2011 | 05:25 PM
wildandwillin's Avatar
Help
That is ur evap canister. Yes it reduces your efficiency and will throw codes and give you a gas cap light. They are cheap and easy to replace..... buy a skid plate or relocate it.
Old Aug 24, 2011 | 01:34 PM
tncruiser's Avatar
Default thanks all
went to dealer will be replaced fri when part comes in
brianj
Old Aug 24, 2011 | 01:52 PM
Noxian's Avatar
Should also ask if you can order a evap skid from a 2012 from the dealer too, might be cheaper that a aftermarket solution,
First part I ordered for my 2011 was a evap skid already put a good dent in it too
Old Aug 24, 2011 | 01:58 PM
brianj
Get a skid for it
