Help! Brakes are squeaky. Not Average
Old May 22, 2013 | 07:06 AM
JK yeti's Avatar
Ok so this isn't your average brake squeak. It only happens when my foot in NOT on the brake. As soon as I apply a tiny bit of pressure the squeak goes away and as soon as i let go its back. I took apart the calipers and greased the back of the pads and it STOPED the sound for about 2 days. Now its back. My pads look good and so do the rotors. Will post up a sound clip tonight! It makes a squeaky sound when i go over speed bumps or any bumps of that matter. Super annoying. What should i do? New rotors and pads? And the sound only comes from the rear
Old May 22, 2013 | 07:10 AM
1995nscajeep's Avatar
Mine was doing that a few weeks ago and I changed my brake pads and now it's all better.. You also might have a rock stuck between the rotor and shroud
Old May 22, 2013 | 07:11 AM
Pghchamp's Avatar
bent axle flange?
http://www.youtube.com/watch?v=vame1AE7eOg
Old May 22, 2013 | 07:16 AM
Offroad_Elements's Avatar
Former Vendor
CRC Disc Brake Quiet
^This solved it for me. Same symptoms as you mentioned; apply this crap to the back side of the brake pads and reduces any play in pad/caliper.
Old May 22, 2013 | 07:17 AM
JK yeti's Avatar
Originally Posted by Pghchamp
Oh my god i love you how do i check this?
Old May 22, 2013 | 07:22 AM
Rob 12B1P's Avatar
When I was diagnosing mine I chocked the front wheels and put the rear end up on jack stands. Remove the rear wheels and start it up and put it in gear.
Old May 22, 2013 | 07:40 AM
JK yeti's Avatar
Well another question would be how to i fix this
Old May 22, 2013 | 07:43 AM
JKphotoshoot's Avatar
New rear axleshaft.. Good time to upgrade !!
Old May 22, 2013 | 07:45 AM
JK yeti's Avatar
:( oh well, it was gona need to be done sport or later. Which brand do you guys recomend?
Nothing outrageously expensive though.
Old May 22, 2013 | 08:40 AM
Rob 12B1P's Avatar
10Factory, Alloy USA, G2 all make chromoly replacements for barely more than replacing with the weak ass stock axles.
