HELP ESP,ABS,Traction Control lighs
Old Nov 6, 2017 | 06:12 AM
Adakar's Avatar
Default HELP ESP,ABS,Traction Control lighs
Hi my friends
I need your help
Recently the ABS ESP and traction control lighs start to pop up in my jeep less than a minute a few times.
I take off the ABS Speed sensors, clean them, check cables etc. But today again the lights turn on for 10 or 15 seconds......
Any Ideas??
My suspension is standard, just change the shocks and put a set of KONI Adjustable ones.
I really apreciate the help.
Cheers
Old Nov 6, 2017 | 06:15 AM
Adakar's Avatar
By the way
I take the jeep to scan and no ABS codes
Cheers
Old Nov 6, 2017 | 09:23 AM
Chewmeista's Avatar
Mine did the same thing. What year and mileage do you have? mine's a 2016 and had about 12k on it. Dealer replaced the speed sensor and wheel bearing under warranty. Even with a lift and larger tires.
Old Nov 6, 2017 | 09:35 AM
Adakar's Avatar
Hi thanks for the reply
My jeep is 2009 with 81.000 kms (like 50500 milles)
Do you know wich one of the sensors and bearing fail in your jeep??
in other forum read "always fail the left rear one..."
Cheers
Old Nov 6, 2017 | 10:51 AM
Chewmeista's Avatar
on mine it was the front left side.
Old Nov 27, 2017 | 08:56 AM
Adakar's Avatar
OK Update
Take the jeep to a friend who have a professional scan tool (like 1000 USD scan tool)
Show problems with the rear left Speed sensor.
My friend fix the problem, first check the sensor, then found 2 little cuts in the cables.
So we replace the cables and fix the problem......
The scan tool also show some problems with the stereo
Old Nov 27, 2017 | 12:26 PM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by Adakar
OK Update
It's pretty nice how detailed real scan tools get. Seen the SnapOn scanners in action and dang it was nice how far it narrowed things down. Nice to have a friend with a tool like that. Simple scanner is adequate for most things.....but nice to have access to a real one from time to time.
Old Nov 28, 2017 | 03:52 AM
Adakar's Avatar
Yes a real Scan tool makes the difference.
