HELP HELP fluid leaking
SubscribeI was under my jeep today and i noticed some fluid on the inside of my rim... when i looked closer i smelled it and i could not tell what it was then i tasted it and it is diff fluid. is it possible that the rear bearing seal is bad. i think i saw a few people on the forum who had the same problem... i took the drum off and i can see the fluid dripping out from the bearing seal i think... help input needed
Quote:
That is a fix under Warranty...take her in!Originally Posted by Petzl7000
Quote:
Originally Posted by pkdailey4
Dog piss ? You should be carefull of what you lick off your rims.
is it the pinion seal i called the dealer they said it might be that.... i have to bring her in today and this sux cause my bumper is coming today
Quote:
PK I swear it's the first thing that crossed MY mind..........Originally Posted by pkdailey4
