Help Identify Screw..Soft Top
Hey guys I need a little help here. I went to put my soft top back on because a storm was coming in and I noticed that the bow on the soft top was missing a screw. Now the bar that connects to the bow is all over the place. Does anyone know what screw this is so that I can replace it? It's really bothering me
Here is a pic.
There are two screws and the one on top fell out.
.Here is a pic.
$4.99 at Quadratec. A bit pricy. You can also use a regular screw with a plastic or metal sleeve.
http://www.quadratec.com/products/11132_9148.htm.
Here is a pic.
.Here is a pic.
I bet they are the same ones used to hold the arms on the rear brackets, the brackets on the rear part of the cage. Take one of those off and test it. If it fits go to your local hardware store or bolt store and get a few matching ones. They might not be black or use the Torx 30, but the thread and length should not be too hard to match.
Also, check all the other screws on the soft top frame. I found several more that were very loose. I re tightened them all with a little blue loctite so it wouldn't happen again.
+1. I lost one of these same screws. I took one out from the other side and found a perfect match at lowes. Got a pack of 4 for under $2.
glad u fixed it... also i check all my soft top screws occasionally as i found one on my floor one day, decided to hold onto it, and then when spring came and i opened the top i discovered where it goes!
