HELP: JKU Cargo Tie Down Screw
Old Dec 27, 2020 | 11:36 AM
kpuscg04's Avatar
Default HELP: JKU Cargo Tie Down Screw
I've run into an issue removing the middle tie down torx screw on the passenger side of my JKU cargo compartment. This is screw farthest from the tailget that secures the interior fender trim panel to the bed of the JKU. The screw is just turning freely without backing out or setting in deeper. It is currently about a quarter of an inch from being fully seated. I can get underneath the plastic side panel and cut the screw, which would free the plastic trim panel, but I'm not sure how I would be able to get the remainder of the screw out of the insert, or permanently repair. Any suggestions would be greatly appreciated.
Driver side example
What is this called? I believe this insert is spinning freely on the passenger side which is preventing the screw from being removed.
Old Dec 27, 2020 | 05:08 PM
OscarMlke's Avatar
Its a swaged nut with a flanged head. The nut is forced into the body hole and is suppose to be a tight fit. But as you've said the flanged nut is simply spinning around. You're going to have to be a bit creative to extract this. Possibly drill this out completely, then set in a new type nut and bolt system. Not sure you can press in a new nut, so you may have to get creative. Possibly weld a new nut in place.
Old Dec 28, 2020 | 09:31 AM
resharp001's Avatar
Loved
Community Favorite
This is an instance where having the ability to weld is the difference between a 30-sec fix or a headache. Welding sure opens up an entire new world of problem solving.
I can't recall the exact size/thread pitch on those bolts off the top of my head, but I'd imagine you could find a corresponding nutsert to stick in there if you can get the old nut out. You can install a nutsert with simple screw, 2 bolts, and spacer cobbled together as a "tool" along with a couple wrenches. It's not as easy as having the proper tool but it's doable, especially for only needing to do 1.
**just noticed you're in Jamaica. Probably doesn't help any in sourcing something like a simple nutsert off ebay.
Old Dec 28, 2020 | 10:11 AM
kpuscg04's Avatar
I had a feeling this would end up being solved with welding.
If I’m able to weld the existing insert to the bed, I may be able to extract the screw and save the insert. I’ll have to check it out.
I can get access to a welder, the challenge is making sure I have all the parts I’ll need first, shipping can take a couple of weeks here.
