HELP!! Key IN Ignition Message
Old Jul 14, 2012 | 02:14 PM
blacknwildjku's Avatar
Default HELP!! Key IN Ignition Message
Guys,
2012 JKU Sport
I am new on here had the jeep 2 months next week. I decided to put some LEDs on my reverse lights today and License plate lights (simple Ebay ones) and also my front fogs which I rarely use. Installed everything in 30 mins. I back it out of the garage and take the key out. Message still says Key in Ignition. I turned it on and off, even took it for a drive, used the second key, no luck same thing. Since thats what the CPU thinks i cant use my Fob to lock the doors and when the door is open I cant lock the rest of the JEEP Only when its closed can i lock the other doors from inside.
ALl lights work inside and outside. I have not done anything major to have this happen just plug and play stuff. car drives fine turns on fine everything else seems normal
ANy ideas?
Blacknwildjku is online now Report Post Edit/Delete Message
Old Jul 15, 2012 | 06:30 AM
Dralphy's Avatar
Disconnect your battery for 10 minutes, and retry.
